查看: 3866|回复: 0
Joint tech A2547 Triple Row Pin Header DIP HR连接器
174
750
发表于 2016-7-5 10:12:45 |只看该作者 |倒序浏览
                        A2547 Triple Row Pin Header DIP 连接器
                间距:2.54mm
型号:A2547
                Current Rating: 3A AC, DC
Voltage Rating: 250V AC, DC
Temperature Range: -25 deg C ~ +85 deg C
Contact Resistance: 20m Omega Max.
Insulation Resistance: 1,000M Omega Min.
Withstanding Voltage: 1,500V AC/minute
GMT+8, 2025-11-3 14:23 , Processed in 0.066354 second(s), 19 queries .
